11-07-2022 14:24
11-07-2022 14:24
Hi,
I wore my sense in the shower and afterwards it had a white stripe on the left hand and right hand sides. They’re extraordinarily bright! I’ve tried restarting it and it hasn’t gotten rid of the stripes. Is there a fix for this? I bought it in Sept 2020. I thought it was meant to be water tight up to 50m under water.
11-09-2022 02:15
11-09-2022 02:15
Hi, @Tia-KT, welcome, Your "Sense" should not have any problem with a regular shower (I swim with mine daily) Allowing you have tried a reset I suggest you talk to "Customer Support" using the chat facility or phone for a prompt response.
I hope this helps.
Cheers
Gr4ndp4 | UK
