01-25-2021
		19:35
		08:16
			WilsonFitbit
		01-25-2021
		19:35
		08:16
			WilsonFitbit
Just got the sense last week. Went to put it on charge, got it off charge when done and it won't turn on. Just vibrates and the fitbit icon will come on screen like trying to boot up but doesn't. I've tried holding button to reset, nothing. I've tried I'm pairing and pairing back and can't bc it says device is off...not happy with the amount of money I just spent for this to happen a week later.
 Best Answer01-25-2021 21:20
                              01-25-2021 21:20
Hi,
This may be a silly question but did you install the Fitbit app and follow the setup procedure to add the device to it?
 Best Answer01-26-2021 03:11
01-26-2021 03:11
Yes, it was synced to my phone fine up until yesterday. Took it off to charge it checked it within that period it was in 55% and was still turned on everything was fine so I let it keep charging then went back to get it later and it was off and will not come back on.
 Best Answer01-26-2021 03:35
                              01-26-2021 03:35
When you open the Fitbit app, do you get any error messages.
 Best Answer01-27-2021 08:11 - edited 01-27-2021 08:11
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hello @Sbharris Welcome to the Community Forums! @Guy_ @Rich_Laue Your input is very appreciated!
I was told by our Support Team that you contacted them and they are working on your case. If you have additional questions or comments, I suggest you to update your case so they can continue assisting you.
Have a great day!
