Hello @catherine.ford, welcome to the Community Forums! @Rich_Laue it's great to see you around and thanks for your input!
As @Rich_Laue said, it would be great if you can provide more details.
In the meantime, please confirm if your Sense goes through the whole process to start a run. Also, are you able to end the activity or does it end by itself?
On a side note, you can try to perform a restart by doing the steps here.
I look forward to you response.
Best AnswerMy Versa 3 does the same thing, probably to do with the touch screen. Probably explains why high end sports watches rely on buttons only.
Best AnswerMy feeling that this is the Auto-Recognize Run setting. I just changed it and we'll see what happens. Just in defense of Catherine I've had this happen mysteriously without the Sense on my wrist at the moment of activation (originally I thought it was activated from inadvertant touching of the button due to clothing, wrist position etc). So short of beginning to believe in the supernatural :), I think it's this. Will check back in and let you guys know
