07-17-2021
04:29
05:47
WilsonFitbit
07-17-2021
04:29
05:47
WilsonFitbit
I have a question, how come when i use my Fitbit sense during my bike rides, I always lose the GPS connection? How do I reset it? Or what can I do to make it work during the full bike ride?
Moderator edit: subject for clarity/format
Best Answer07-17-2021 05:53 - edited 07-17-2021 05:55
Hello @NoahE23. Welcome to the community forums!
Thank you for the information. Regarding your questions, I'd like to let you know that there are some factors that could cause your Sense to lose GPS signal, for example, if your Sense has battery short life. Also, environmental factors, including tall buildings, dense forest, steep hills, and thick cloud cover, can interfere with your device’s ability to connect to GPS satellites.
If the signal is blocked; either because you're indoors, underground, or due to another reason, GPS won't work. At this time, I'd recommend taking into consideration the following tips:
Make sure that you have a clear view of the sky when you start the exercise. Environmental factors, including tall buildings, dense forest, steep hills, and thick cloud cover, can interfere with your device’s ability to connect to GPS satellites. If the signal is blocked—either because you're indoors, underground, or due to another reason—GPS won't work.
Hope this helps.
