06-28-2021
22:33
16:34
LizzyFitbit
06-28-2021
22:33
16:34
LizzyFitbit
My Fitbit sense has lost its clocks. The only one that I still have only shows the time everything else is missing. Has this happened to anyone else? I’ve only had it for six months.
06-30-2021 07:24
06-30-2021 07:24
Hi @Leah1111. Welcome to the Community Forums.
Thanks for bringing this to our attention. To work on this, may I know if by losing its clocks you refer to your Sense not showing your 5 clock faces saved in the Clocks App? Or is the issue with the clock faces not showing your details? If possible, please take a picture of what is displayed on your watch and attach it to your reply.
In the meantime, let's give a try to the following:
Hope this helps.
07-01-2021 18:05
07-01-2021 18:05
07-04-2021 13:15
07-04-2021 13:15
Hi @Leah1111. It's good to see you again.
Thanks for trying the suggestions posted above. I'm sorry the issue persists and to work on this, could you confirm the name of the clock face you're using on your Sense? Have you tried changing the clock face to see if others work? Additionally, please take a picture of what is displayed on your watch and attach it to your reply as this will help me to further investigate on my end.
See you around.
04-25-2022 15:55
04-25-2022 15:55
Hi Lizzy
im also having that problem except I have lost all clock faces. I followed your instructions above but with no luck. To make things worse my iPhone cannot now detect my sense. (I’ve tried restarting my phone but still no luck)
Do you have some further suggestions?
thanks Michelle
04-25-2022 22:33
04-26-2022 16:54
04-26-2022 16:54
@madams63 Welcome to the forums. @Guy_ Thanks for your help!
@madams63 I'm sorry your Sense isn't displaying your clock faces and thanks for trying the steps suggested in my post. If you haven't done so, let's give a try to the tips shared by @Guy_ to see how your watch behaves afterward.
In regards to your other inquiry, please review this help article which describes what factors might prevent your watch from syncing, as well as some troubleshooting steps.
