04-23-2021 21:46
04-23-2021 21:46
i ask customer service but i get ansver " try different charger"
what is max amps watch can get? 5v 1amp, 5v 3amps......?!?!?!? No detail manual 😞
Best Answer04-25-2021 04:48 - edited 04-25-2021 04:49
Hi @HelloMate.
All the user manual states is the following :-
Plug the charging cable into the USB port on your computer, a UL-certified USB wall charger, or another low-energy charging device.
Is there a reason why you need to know the detailed specifications? As this is predominantly a user based forum, it's unlikely anyone here will know the definite answer. I use an old iPhone 4s charger to charge mine (as I know its low power) and haven't had any problems.
