03-27-2021
22:37
15:31
LizzyFitbit
03-27-2021
22:37
15:31
LizzyFitbit
Hi, the microphone of my fitbit sense doesn't work, I already restart, power off and factory reset the watch and still doesn't work. I tried with a call and the speaker it's working fine but the other person can't hear me. I Also check if it's turned on in settings. Someone help me! Thanks. I'm using Android 11.
03-27-2021 23:08
03-27-2021 23:08
Awesome troubleshooting Fernando,
Does the issue occur when calling anyone, or by calling to someone in particular?
In case it happens by only one person, s(h)e may need to restart her/his phone and/or check if phone call volume is not at a low setting. Otherwise the support team can be contacted.
Best Answer03-27-2021 23:31
03-27-2021 23:31
It happened in more than one call with differents persons. Also I can't use the voice assistants because they didn't recognize any sound and says "you can try with how's the weather" and stuff like that.
Best Answer03-28-2021 07:44
03-28-2021 07:44
On the Sense Have you swipped over to the settings. Then under Vibration and Audio is the microphone turned on?
Best Answer03-28-2021 07:53
03-28-2021 07:53
Yes, it's turned on. If I shout out the the watch the person on the other side of the phone can hear me.
Best Answer04-18-2021 04:52
04-18-2021 04:52
I think there is an issue with the Sense microphones being defective. I started asking questions on here in February, was finally directed to call the fitbit support number who made me do a lot of troubleshooting over the phone and then said they would open a ticket for me. I received an email saying they were looking into the issue and to please be patient with them. After a month of no response I replied to their email asking for a solution. Again they asked me to do a few more troubleshooting things that still didn't work. Then I had to answer questions about date and place of purchase and now I've been sent a shipping label to return my fitbit to get a new one. I should start that process tomorrow.
04-18-2021 06:04
04-18-2021 06:04
I have also sent mine back for the same reason. Very very frustrated.
04-18-2021 10:50 - edited 04-18-2021 10:51
Best Answer04-18-2021 18:17
04-18-2021 18:17
Yes, i tried that. I sold the watch, maybe it was factory damaged and Im outside the US.
Best Answer10-04-2021 15:59
10-04-2021 15:59
I called them 3x about once answering a call I can’t hear the caller and they
cant hear me. They had me upgrade to iOS 15, do a factory restart on the watch, turn Bluetooth on and off on my phone, Forget the sense control, turn the watch off and back on and
all sorts of other things! All multiple times! Enough to drive me crazy and give me a head ache. After doing what they told me to do 3x and nothing working, I contacted Amazon to
return it for being defective. They are supposed to replace it with a new one. I really hope the new one works because I like all the heath tracking. It costs too much money to not be able to
do calls. Very annoyed and disappointed!!!
Best Answer11-30-2021 12:56
11-30-2021 12:56
Unfortunately this same thing happened to me. I was sent a new fit bit sense and in just 2 month the same thing happened again so now I have 2 senses with microphones that don't work. It's definitely a defect in the sense because I've read that hundreds of people are having the same issue. I think they need to do a recall on them.
08-04-2022 15:42
08-04-2022 15:42
You cannot use the mic to make outgoing calls on the sense you can only use the mic when someone calls you. It's ridiculous
Best Answer08-05-2022 07:37
08-05-2022 07:37
Let's keep this thread on microphone hardware issues.
Have you added your vote @AKARAS?
Make calls on the Sense It is suggestions with active votes that get attention .
Best Answer08-05-2022 07:45
08-05-2022 07:45
Yes, thanks.
