03-09-2022 16:15
03-09-2022 16:15
My floor count is tracking wrong. It's giving me hundreds of floors when I've probably only done 6. I've restarted it several times
03-09-2022 17:41
03-09-2022 17:41
Welcome to the Fitbit community.
There's a lot of posts about this. The issue is the altimeter and/or algorithm are sensitive.
03-10-2022 04:07
03-10-2022 04:07
Hi @Dbaby - as @eezeepee says this affects all those interested in tracking floors and has not been fixed.
If you are really interested in how your watch pressure sensor is behaving or whether you can get a more accurate floor count, you can verify you don't have a watch problem by using the SimpleFloors app.
The App shows how your watch is affected by environmental issues such as, going room to room, upstairs/downstairs, inside to outside, changes in temperature, etc.
This App is only meant for checking purposes as it uses the battery a lot, but at least it will give you an idea if your watch is fine and if it is some other issue.
