Sense mobile app numbers are not recorded to Sense Fitbit. Wear on left wrist while walking on treadmill and have mobile phone in pocket to record steps. Upon sync, wrist number overwrites mobile numbers
I think the only way steps from phone would go to Fitbit database is if you have "Mobile Track" set up as a Fitbit device. And if you were even able to have "Mobile Track" plus Sense set up, Sense data would always override phone data.
Even if you were able to do that, would you want all Sense data overridden by phone? even heart rate data? You couldn't expect it to keep steps from phone and heart rate and calories from Sense and somehow know how to merge them. And how would Fitbit know when to do that? How would it know to not always take phone data over Sense?
If you do want to use steps from phone, the only way I know of would be to manually log the workout afterward, based on phone's steps. But that would override all data from Sense, including heart rate and calories. If that is what you want, there is no reason be wearing Sense during workout anyway.
In short, your choice is to use the mobile track option on the phone, with the phone on your pocket or use the Sense to count the treadmill steps.
To use the phone, you will need to take the sense off your arm.
Best AnswerThanks, you are correct. I just didn't know my Sense had a function for treadmills or I wouldn't have posted.
Thanks again
Best AnswerBut be aware, even in "treadmill" setting, if you are holding handrail, you probably will not get steps, and therefore distance, counted.
Best AnswerFitbit has decided not to sync directly with any other hardware. However fitbit has an open API that allows Third Party Apps to sync with a fitbit account. It may be possible for them to setup a sync with fitbit. (I have a spreadsheet that records everytime I charge my tracker and another that records my daily steps)
Just a note about holding on to the rails
Best AnswerThanks for your input, I agree with that one update would override the other so what's the point in having both on my person while doing anything I want to track? While a member of Life Time Athletics I had several apps going all at the same time as workouts where synced between phone app and treadmill, another app for nutrition monitoring, and another app for biometric analysis. Again, thanks for your input.
Best AnswerYou can use any app you want on your phone for steps or distance, or anything else. But don't expect them to necessarily tie into your fitbit data.
