Sense no longer tracking my sleep score
Why has the daily sleep score disappeared on my Fitbit Sense? I saw something about a new way of recording sleep over a longer period but I would rather have a daily record. Can I change it back in settings?
4 REPLIES 4
Are you a Premium member?
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
Yes.
Thank you for sharing this information about the inconvenience you've been experiencing with your Sense.
When your body is completely at rest and you haven’t moved for about an hour, your device should record that you’re asleepBefore considering other options, please keep in mind that there are some factors that may prevent your tracker from recording your sleep stages today. Please make sure of the following:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device as described in this help article.
  • If you slept for less than 1 hour for sleep patterns or less than 3 hours for sleep stages.
  • If your device’s battery is critically low.
If you haven't done so already, please follow the steps listed here below:
  1. Complete a restart procedure.
  2. Try adjusting the sleep sensitivity on the Fitbit app and check if you continue to have the same problem.
In addition, please wear your device on your non-dominant hand and monitor it for the next few days. In the meantime, for the nights that don't have sleep data, you can manually log your sleep by going to the Fitbit app, tapping on the "+" icon next to the sleep tile > Add Sleep Log and entering your details.
Several reasons you may not be seeing your sleep score on your Fitbit or inside the Fitbit app. It could be an issue with syncing, the app version you are using, the App's settings, or heart rate reading and settings.
Regards,
Will
