I'm a long time Fitbit customer however this Sense/iPhone not syncing situation is making me doubt it's future on my wrist. You guessed it, I have the same issues you find in many of the posts below. I've done all of the suggested fixes several times, with no results for the past 10 days. Yep, I have the latest firmware and iPhone Xs updates too. I'm considering for my step a reenactment of the epic scene from Office Space and grab my sledge hammer, go the park, and film myself destroying this culprit. Before I do I wonder if anyone has actually been able to sync and keep it sync'd?
Best AnswerI just contacted support with the same issue. They attempted to guide me through the troubleshooting again. If your Sense is still under warranty, they may help you replace it if you talk to them. I used the chat feature.
Best AnswerNope. Not able to. If I shut down my phone and my watch and then “remove this device” from the Fitbit app and reinstall it…..it will sync….one time only. Then it goes back to not syncing. I agree with going office space on this thing. I might be joining you.
Best AnswerThis happened to me on weekend was very frustrating
deleted app, did phone update then it was ok
however since my sense won’t keep charge for more then 5 hours ish when it used to be 5 days!
Best Answersame but I was able to fix the battery depletion problem with a factory reset. The sync problem not yet 😡
