i have had my sense for a few months now but it has stopped charging all together. I have attempted to reset it following advice on other similar posts with zero luck. I have also used three different chargers, all again with zero luck.
Charger is aligned properly every time. Contacts are clear and clean.
Please, any advice helps. Will be contacting chat support tomorrow.
Best AnswerHi @Tubacca123 Have a look at THIS Help Article on battery problems. If nothing helps then you will need to contact Customer Support
Helen | Western Australia
