12-03-2020 06:29
12-03-2020 06:29
Very frustrating. I just got the Sense and it us not pairing to my phone. Spent over 400 CAD on this smart watch. Any suggestions
I won't spend so much time troubleshooting, if not fixed today, I am returning it
12-03-2020 06:34
12-03-2020 06:34
Seems like everyone wants to return this watch.. you can try out the tips here. https://community.fitbit.com/t5/Android-App/Tips-for-Syncing-to-your-Android-Device/m-p/4469690#M137...
Best Answer12-03-2020 10:56
12-03-2020 10:56
Are you trying to pair it directly to your phone through its bluetooth connections and getting a 'refused' error?
This is normal. You don't pair the Fitbit to your phone directly, you add the tracker through the Fitbit App and IT negotiates the bluetooth pairing on your behalf. Please try that.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
12-04-2020 07:39
12-04-2020 07:39
Please include what steps you are doing @SandyEnr
At what step the failure occurs.
Any error messages.
The probablem with only saying it don't work when we can not see what is going on, gives us nothing to work with.
Best Answer12-04-2020 12:48
12-04-2020 12:48
I also have been having issues with my new sense and my Samsung s9+. I won't relay phone calls or text to the sense. The fitbit ap is updated, all the notifications on the fitbit ap are enabled. I have done the whole process with the Bluetooth set up having the sense sending numbers to my phone and my phone recognized it. The issue is, when I go to my phone settings, go to Bluetooth settings, it says sense controls connected. But when I tap on the ⚙ on the right next to it and open up the sense controls screen it has two options, one says calls the other is imput device. The imput device toggle is on but the calls toggle is off. I keep sliding it to on but it automatically slides back to off. I have already had my phone Bluetooth forget the sense controls and re installed the sense controls multiple times, I have also restarted my phone. Neither has worked.
12-04-2020 14:51 - edited 12-04-2020 14:52
Having the Sense send numbers to your phone is not connecting the Sense to your Bluetooth. This is setting up your Sense to your Fitbit account. Once the tracker is connected to your account, the Fitbit app will ask to pair the tracker to the phone.
Opening up Bluetooth, the Sense should now be listed, and is telling you that the Sense is a trusted device. The Sense should not show up as connected.
Being trusted means that when communication between the two are requested. Permission to connect is approved and the two should connect.
A restart of the phone will only restart the software. Sometimes the hardware needs to be reset and only a phone shutdown will fix this.
@Aaig we want to check the phones Bluetooth for the Sense to be listed. To answer calls through the wrist we want Sense Controls to also show in the list.
Swipe down on the screen and open Settings - Apps - Fitbit - power or battery - not optimize or disable management.
Now let's open the Fitbit app - Account - Sense - Notification.
Tap the 3 dots in the top right corner and send test call.
If it fails. Disable Notifications and re-enable. You should be asked to accept some permissions. You need to agree to them.
Back out of screen and enable the different notifications.
Keep us updated.
12-04-2020 20:36 - edited 12-07-2020 07:40
@Aaig this is my phones Bluetooth.
Sense Control is paired, not connected.
Tapping on sense controls will start the connection process and fails.
Tapping on the Sense Control settings gets me to this screen.
My sense controls work and I'm able to talk through the phone.
Before we look into sense controls, we need to get notifications for phone calls working.
Yes I'm watching YouTube.
12-06-2020 08:19
12-06-2020 08:19
I is now resolved. I am able to receive phone calls and answer text. Thank you.
03-18-2021 05:09
03-18-2021 05:09
Exactly what's happening with mine!
Best Answer03-18-2021 09:48
03-18-2021 09:48
Exactly what is happening with you @Mellymoomoos
Is it about the Sense, or the hijacked conversation with the sense controls?
Or to ask another way.
Can you answer a call through your tracker, or does the tracker not sync?
Is the tracker even connected to your fitbit account?
