08-06-2021
08:31
05:31
WilsonFitbit
08-06-2021
08:31
05:31
WilsonFitbit
I am having the same problem. But, I did choose the "Begin Sleep Now" option on the app. Would that cause it to not record my sleep stages?
Thanks in advance for any reply or help.
Michael
05:34
09:57
08-07-2021
05:34
09:57
Hello @Blazinpistol. Welcome to the community forums!
Thank you very much for the detailed information. I'd like to let you know that there are a few scenarios such as using the "Begin Sleep Now" option that prevents sleep stages to be recorded.
At this time, I'd recommend taking into consideration the following information and tips:
For more information, you can see: What should I know about Fitbit sleep stages?
Hope this helps.
