05-13-2022 08:50
05-13-2022 08:50
My Fitbit Sense was charged as normal to 100% at 7am. By 11am the watch battery level was down to 16%. To try to preserve what little battery life the watch had left, I set to sleep mode and took watch off until end of work day (5pm). Watch was dead by the time I got home. I charged the watch again but this time it never turned on. When I remove it from the charger it vibrates continuously but does not turn on.
-- I have cleaned the back of the watch and the charger contacts as recommended (though the watch and charger weren't dirty).
-- I have long pressed the haptic button (10 seconds, at least) with no response except for the vibration to stop at 10 seconds until I stop the press then the vibration continues.
-- I have had no issues with watch until now.
Has anyone had any similar watch behavior with success to start?
Best Answer05-13-2022 11:34
05-13-2022 11:34
Hi, @JSSA , this sounds like an issue for Fitbit Customer Support. You can reach them on Contact.Fitbit.com . Be sure to tell them the troubleshooting steps you have already tried.
05-14-2022 06:53
05-14-2022 06:53
It's not you, or your device. A number of Fitbit users are also experiencing this issue after a recent firmware upgrade.
https://community.fitbit.com/t5/Sense/Sense-shows-only-the-Fitbit-logo/td-p/5127855
