09-29-2022 07:34
09-29-2022 07:34
I got my sense this year to replace my Ionic. It stopped synching this morning at 12:08. It also did not track my sleep. What can be done to solve this?
Andy
08:39
14:01
09-29-2022
08:39
14:01
Hi @AndySchober - usually restarting the phone and watch restores the syncing and sleep information will appear.
It is calculated so if it doesn't get to the Fitbit App it can't be processed, that's why syncing is important to fix.
Here's the general link if there is still a problem. Why won't my Fitbit device sync?
09-29-2022 09:29
09-29-2022 09:29
Thank you, that worked
09-30-2022 07:20
09-30-2022 07:20
Guy,
Do you have issues at times with your sense not tracking floors?
Andy
07:47
11:12
09-30-2022
07:47
11:12
@AndySchober- a firmware update messed up my watch. It was counting fine before then just gets random floors.
What is curious, due to a fault it was replaced, it is still on but not worn and now counts no random floors, which is correct.
I use the SimpleFloors app to monitor the pressure changes The new one wanders less and counts almost correctly.
Hope that helps.
Best Answer09-30-2022 12:43
09-30-2022 12:43
Thank you Guy, That helps. It is weird as I usually only have the issue at work and not here at home. I jusy got my sense this year to replace my Ionic. Are you getting the Sense 2?
Andy
