After switching Fitbit accounts, a trick I found that often helps syncing/pairing is
Login to the Fitbit App, Pull down to refresh, [after the sync popup appears at the top, and if its not got a progress bar]
Click on profile photo [top left] Device photo [middle left] Sync Click on the circle
After a few seconds If no pair prompt appears Go back to the Today screen Repeat the process |
This assumes that the device is not currently synced/paired with the App or has already been "forgotten" in Bluetooth settings from prior troubleshooting.
08:27
05:45
01-22-2021
08:27
05:45
Hello @BobbyL Welcome to the Community Forums! @Guy_ @Rich_Laue Thanks for your input!
@BobbyL I was told by our Support Team that you contacted them. Since you have received assistance from them, I suggest you to update your case if you require further assistance or if you have any additional questions about the outcome of your case.
Have a great day!
