06-27-2021
08:20
15:42
SilviaFitbit
06-27-2021
08:20
15:42
SilviaFitbit
Sleep data works then doesn’t. Frustrating! Before SP02 update, data recorded every night. Now adding the O2 saturation, changing the clock face so it records, causing problems even recording data I never had a problem with before. A couple times it will work and then does not work for several days.
15:45
05:31
07-10-2021
15:45
05:31
@Litrails Welcome to the Fitbit Community. Thanks for the details mentioned.
I see where your frustration is coming from. I appreciate the troubleshooting performed prior to posting.
I was able to see that you have a case with our Support team. In regards to the sleep data not working as expected, there are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
Hope this helps.
