Sense automatic fall back into default Time-UI mode
There is an annoying fitbit sense behavior. Every time you have used some special feature, like the timer, EDA-Scan etc., the watch will remain in that mode for ever. But in more than 80% of the watch uses, you just want to see the time-UI. In those cases, you always must move back, sometimes through 3-4 clicks, in order to get in the time-UI mode.
1 REPLY 1
@pkindzie Welcome to the Fitbit Community. Thanks for the detailed information shared.
I see where your disappointment is coming from. Let's try restarting your Fitbit Sense and continue monitoring its functionality. Are you still experiencing this with your smarwatch? Does it happen when you use any other feature?
Hope this helps.
