Just bought a new Fitbit Sense. Blue tooth pairing with my iPhone 11 is constantly dropping.
i have tried the following.
1. Updated the Fitbit App
2. Restarted my iphone
3. In iPhone settings,- Bluetooth - Sense- forget this Device (then I have reconnected successfully after that but only for a short time). Step 3 has been repeated countless times.
Can anyone advise please. I am feeling pretty disappointed with my new toy!
04:54
12:43
06-07-2022
04:54
12:43
Hi @Aucklandsummer - it is most likely a phone issue, the Fitbit App needs to run in background, so if you close it or the battery saving closes it, it stops syncing.
Also only the Fitbit app can do the pairing, it can't be done in Bluetooth.
The SimpleCheckUp app may help you see from the watch if it can connect to the phone or not which may help with fixing it.
Often
Will get you going in the interim.
