My sense is randomly changing time to one hour later. This happened multiple times over the last few days. Syncing does not help resetting time, time will eventually switch back to the correct format. At this point the watch is not usable for its prime purpose as showing the time.
Location
I assume it might have something to do with fitbit thinking Spain is cet (which is correct for mainland Spain) however the canaries are in gmt as is ireland
Troubleshooting:
App-Settings in fitbit
Android settings
Versions
I am aware that I can set the time zone however this defeats the purpose of it adjusting automatically. Any assistance or explanation is appreciated.
08:38
11:53
03-17-2022
08:38
11:53
Hi @Karosch - good reporting, some options
Hey @Guy_ thanks for the swift reply. Replies to your help below:
Hey @Guy_ ,
Apologies for the late reply, vacation unfortunately ended too early and so did the clock issue.
However I was able to get some additional data on timezones:
The SimpleCheckup app confirmed that the watch set itself to utc+1 when the issue occurred. Once it self-resolved the watch switched back to utc+0.
I was unable to reliably reproduce as I am not 100% sure what caused this issue. I suspect its connected to loss of network: re-registering and possibly wrong geo location data, tho I am not an engineer! 🙂
I'll be going to Portugal and Spain mainland soon and will monitor for another occurrence.
Many thanks
Chris
