03-17-2022
06:53
18:51
LizzyFitbit
03-17-2022
06:53
18:51
LizzyFitbit
Help, my SENSE screen is very fuzzy and has vertical green lines. Saw similar problems with Versa and followed restart button but still the same
03-17-2022 07:30
03-17-2022 07:30
@Ging1963 If you've tried a restart and a factory reset and you still are having screen issues, then I think it's a hardware problem with the screen and something that you're not going to be able to fix. You should reach out to Fitbit Customer Support for further guidance.
03-17-2022 07:30
03-17-2022 07:30
