01-30-2022
18:51
17:48
LizzyFitbit
01-30-2022
18:51
17:48
LizzyFitbit
My six month old Sense has suddenly started "waking" after being off for an extended period with a super bright screen. It adjusts itself pretty quickly but is blinding when it wakes in the night. I have tried restarting and resetting but this has not fixed it.
01-30-2022 19:20
01-30-2022 19:24
01-30-2022 19:24
Thanks Guy, yep done that - switched to dim but to no avail. The only time it doesn't do it is if Always On Display is enabled.
Best Answer01-30-2022 19:31
01-30-2022 19:36
01-30-2022 19:36
Thanks. I’ll give that a try.
Best Answer01-31-2022 07:43
01-31-2022 07:43
Sleep mode definitely helps. Personally I manually turn it on and off with the shortcuts when you swipe left to right. That's because days I'm working I sleep earlier. But if you have a good consistent time to sleep, a schedule would be perfect.
Best Answer01-31-2022 11:53
01-31-2022 11:53
Okay so setting a sleep schedule has not reset the brightness sensor but thanks for the suggestion. The screen flashes to almost white before normalising itself so perhaps this is a sensor problem rather than a settings problem?
17:44
04:23
01-31-2022
17:44
04:23
Hi @AJSim. Welcome to the Community Forums. @Guy_ and @eezeepee It's good to see you here.
@AJSim Thanks for bringing this to our attention, and for the steps tried prior to posting. This is an odd behavior and just to confirm with you, may I know the name of the clock face you're using? As you may know, the Fitbit App Gallery has a variety of clock faces designed by both Fitbit and other 3rd-party developers. Assuming you're using a 3rd-party clock face, please get in touch with them to receive more information about it. You'll find their contact details in the clock face description in the Fitbit app.
On the other hand, if it's a Fitbit clock face, I'd recommend contacting our Support team so they can investigate what may be occurring and provide you with further assistance. They're available via chat and phone, just click here to get connected with them.
01-31-2022 18:24
01-31-2022 18:24
Hi LizzyFitbit and thanks for the welcome. I’m using a Fitbit clock face and regardless of which clock I use the issue persists. I reverted to the standard spectrum to see if it is a clock issue but it makes no difference. Thanks for the link to support! Cheers
01-31-2022 18:30
01-31-2022 18:30
@AJSim Yeah that's a different issue you have with a white bright white flash. From what I'm aware of, there's no brightness sensor. That's why it's just dim, normal and max yet there's no "auto".
19:57
08:49
01-31-2022
19:57
08:49
Best Answer02-01-2022 00:30
02-01-2022 00:30
02-01-2022
00:40
08:49
02-01-2022
00:40
08:49
Best Answer02-01-2022 00:45
02-01-2022 00:45
02-04-2022
12:59
04:23
02-04-2022
12:59
04:23
Hi there, @AJSim. @eezeepee and @Guy_ It's good to see you here and thanks for your suggestions.
@AJSim Thanks for keeping me posted, I'm glad you're receiving help from our Support team. I'm sure your case is in good hands so please keep an open communication with them. If you need anything else, don't hesitate to get in touch with us.
Best Answer02-04-2022 13:21
02-04-2022 13:21
Hi @LizzyFitbit the Support Team were super helpful and are sending a replacement device.
02-07-2022
11:13
03:34
02-07-2022
11:13
03:34
@AJSim I hope you're doing well.
That's great news! I'm happy that you'll receive a replacement soon and let me recommend this help article to set it up in your existing account.
By the way, in case you have some spare time, I’d like to invite you to visit our Health & Wellness board where you can find inspiring stories, make friends and start your own topics.
Have an awesome week ahead. 😊
