Hi @DeniAW - this is quite a common problem, especially check the cleaning and the charge cable How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best AnswerHi, @DeniAW, welcome to the community, this occasionally happens to me. The solution is to wash your "Sense" with warm soapy water, pay particular attention to the 4 little contact "pits" in the back of your "Sense" (I use cotton buds which I rotate in the pits) Make sure your "Sense" is dry before attempting to charge. The charging cable coupling can be a little finicky, I wiggle the 4 springloaded pins gently with my finger to ensure they are free and able to complete the contact. You should also consider Why isn't my Fitbit device's battery charging? .
I hope this is useful but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
10:48
11:08
02-07-2022
10:48
11:08
@Gr4ndp4 - for info, it is advised not to allow contact with detergents Can I swim or shower with my Fitbit device?
It is true the pits are prone to collecting debris and how to clean, as mentioned in the link How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
