Sense screen not showing up after setup
Hi,
After setting up my new Fitbit Sense using the app (on a Surface 7) the watch face does not show up. It continues showing the original face "download fitbit app to begin". This is strange because during the synching process the watch was 'co-operating' and responding and after 'successfully paired' it stays with that original face.
Tried restarting and still the same.
On the other hand the app shows that it is connected, but no readings show up either.
Any advice would be welcome.
Thanks
6 REPLIES 6
"REQUIREMENTS
  • To set up Fitbit Aria Air, Fitbit Charge 4, Fitbit Sense, Fitbit Versa 2, or Fitbit Versa 3, you must use a compatible iPhone, iPad, or Android phone. You can’t set up these devices on a Windows 10 device."
click to see the article
Stepping in the U.S.A. since September 2013. Android 14
Thanks, i guess that's the issue, and if I do that, could i then use my pc app to keep it up to date and see all the data collected?
@LICAZ  you'd need to keep the Sense updated via the phone. You can always see your data on the Fitbit site's dashboard, but the phone app does show you much more.
So if I do not have access to a phone, for a while can the update be done
from afar?
[image: Mailtrack]
Sender
notified by
Mailtrack
12/07/21,
08:24:22 PM
@LICAZ  when my Luxe updated, it told me to keep the phone near it. I'm thinking you need to have the device near the phone while it continues updating. Your phone's bluetooth is the bridge that takes you to the Fitbit servers, so I think that is why you need to have device and phone in close proximity.
Welcome to the Fitbit Community, @LICAZ and thank you for your assistance @Odyssey13. Thank you for sharing your syncing inquiries.
You can check: How do Fitbit devices sync their data? help article. If you don´t have access to a phone, you can sync your watch and update your data when you get that access but you need to be close to the phone to sync and update your information. Some devices store the information up to a week without syncing them.
Keep on visiting the forums.
