03-29-2023
10:39
11:52
WilsonFitbit
03-29-2023
10:39
11:52
WilsonFitbit
My screen has popped off my sense and now does not work soooo disappointed ☹️ move to the dark side of Apple iWatch
Moderator edit: clarified subject
03-29-2023 11:50
03-29-2023 11:50
Hi mine to!! Today my screen has popped off my senss not working!!! I don’t know what can i do????
03-29-2023 11:58
03-29-2023 11:58
Do you mean the glass popped off or there is no clock face showing? I had a problem today where it appears that FitBit no longer supports the 3rd party clock I had purchased from them. I used the IPhone app to switch to a different clock face, did a reset and problem solved!
03-29-2023 12:07
03-29-2023 12:07
Oh no 🙈 just there is no clock face showing???
03-29-2023 20:43
03-29-2023 20:43
03-30-2023 03:34
03-30-2023 03:34
Same here! All of a sudden my Sense went to a black screen. Not sure what to do! Very frustrating!!
03-30-2023 03:38 - edited 03-30-2023 03:38
-Check battery strength in app.
-Check charge cable to see if all 4 pins protrude equally.
-Change clock face in app to a Fitbit one.
some faces have been decommissioned.
I
03-30-2023 13:32
03-30-2023 13:32
