02-03-2021 18:58
02-03-2021 18:58
Just a month old and I bumped my sense against my island and now it has a scratch right in the middle of the screen. So disappointed that fitbit isn't able to fix it, what a piss off. I'd pay to have it fixed. I guess this is why you should buy apple. Anyone have any tips or ideas on how to fix this? Google wasnt much help.
Best Answer02-03-2021 19:27
02-03-2021 19:27
I saw online procedures to polish or buff scratches on gorilla glass. Personally, I’d be concerned about making it worse.
Depending on how bad it is, maybe want to consider consulting a watchmaker to see what can or can’t be done.
Best Answer02-03-2021 19:30
02-03-2021 19:30
Hi @Selew just did a Google search myself and saw many suggestions on just what to do with a scratched screen. I did a search using "how to repair a scratched screen on a Fitbit", so you should try a search again. The easiest fix seems to be the toothpaste trick, but I've not used it. A few people have posted on these forums and given their success stories, but I couldn't find them when searching. You could check with a local jeweler and ask them what might work or if they offer such a service.
