12-02-2021
14:47
14:18
LizzyFitbit
12-02-2021
14:47
14:18
LizzyFitbit
when i raise my Sense to view the screen i now see a small white 'something' at the top of the screen which disappears after a second or two. it does not seem to do or be anything but i am intrigued to find out what it is. Any insights?
12-03-2021 01:17
12-03-2021 01:17
Hi @lidzau - Try turning off the status indicator [which was added in the latest version] in the watch Settings, Display, and see if it goes away.
12-02-2021 15:00
12-02-2021 15:00
take a picture of it and post it to get a better idea of what it is..
12-03-2021 01:17
12-03-2021 01:17
12-04-2021 00:19
12-04-2021 00:19
That seems to have fixed it. Thanks Would love to know what it was trying to tell me tho' Cheers Ian
12-04-2021 00:45 - edited 12-04-2021 00:46
@lidzau- Ian, thanks for the confirmation with best answer. Your input helps others.
There seems little documentation but the white dot might indicate the indicators are in the process of being checked. Presumably when the dot disappears all is in order, otherwise an indicator may appear. But that is just a guess.
Also I am guessing again but with indicators checking turned on it may adversely affect the battery, in various ways. If your watch is behaving well it is probably not necessary to have the processing turned on.
On A Sense it is sufficient to swipe the face right to check Sleep or Do not disturb mode and battery level.
The SimpleCheckUp app displays all sorts of watch details, when it last synced, if it is connecting to the phone well or to find the phone [if it's reachable].
Which can be done only if there is a suspected problem, so may save battery.
Best Answer02-16-2022 09:15
02-16-2022 09:15
I think it means that the ‘do not disturb’ setting is on. Mine had it too and it went away when I turned that setting off.
07-22-2022 12:03
07-22-2022 12:03
This is the indicator that the Do Not Disturb function is turned on.
07-22-2022 15:02
07-22-2022 15:02
There are four status indicators on the Sense and Versa 3. Fitbit describes them in this Help article. They are:
The battery use is minimal.
Laurie | Maryland
12-27-2022 06:55
12-27-2022 06:55
This is the correct answer!
