10-11-2020 04:43
10-11-2020 04:43
Hello, is anyone else getting very low voltage readings when taking an ECG with the new fitbit ECG app? I downloaded the app yesterday, and all readings are almost flat but declared 'normal' by the app. I am trying to add a screenshot, but so far the forum is not letting me.
I sit still when taking the ECG and am of normal weight, in my twenties but not in the best shape due to working from home the past 6 months. The reason I got this watch was because of tracking insomnia, since there are days where I'm so exhausted my chest hurts. Didn't expect these results though and am reading into interpreting single lead ECGs.
If anyone has tips that would be greatly appreciated!
10-11-2020 08:13
10-11-2020 08:13
To post screenshot picture, use camera icon above text box.
10-11-2020 10:23
10-11-2020 10:23
Here's an example reading which is similar to the other readings.
Best Answer10-11-2020 10:52
10-11-2020 10:52
This looks like a contact problem. Make sure your index finger and thumb are in firm contact with the opposite corners of the top metal rim and that you are pressing the watch down upon your wrist.
Best Answer10-11-2020 13:30
10-11-2020 13:30
Thanks, but sadly this makes no difference. Loose, normal, tight, all give the same results. I tried cleaning the watch, warming my hands, but to no avail.
Best Answer10-11-2020 13:45
10-11-2020 13:45
I assume you aren't using any screen protectors. Position the watch on the inside of your wrist, then take the ECG. If that doesn't work, then perhaps it's a defective watch.
Best Answer10-12-2020 01:23
10-12-2020 01:23
I tried it on the inside of my wrist, but it didn't change much. And no screen protectors.
I let someone else use the watch and their reading was normal with clear waves, so I guess it's me.
Best Answer10-12-2020 03:56
10-12-2020 03:56
Yves, I have seen your ECG and I think maybe you could better see a doctor if you're afraid that there's something wrong with your health. If I look at my ECG made with the Sense it's almost identical with the one my doctor made some weeks ago.
Best Answer11-27-2020 19:38 - edited 11-27-2020 19:38
Hi YvesNL. With regard to Chronoswiss' comment, did you get medical advice on this? I would be interested in the cause.
Best Answer11-30-2020 13:50
11-30-2020 13:50
Hello,
Due to the current pandemic it's not possible to visit a GP in my clinic for something that is not urgent, so I did not get medical advice. I did buy a 6-lead consumer ECG (Kardia 6L) which had exactly the same results as the Sense, so it's not an issue with the Sense.
11-30-2020 20:28
11-30-2020 20:28
Hi YvesNL. Since you have a Kardia, please see this video - https://vimeo.com/262643364
For an explanation, please go to https://theskepticalcardiologist.com/2018/04/14/
Best Answer12-01-2020 09:57
12-01-2020 09:57
Thank you FloppyDrive, but I have already tried everything mentioned on the blog. Wetting my fingers and making a lead II recording as mentioned in the video does show clearer waves, but still a maximum amplitude of 5 blocks. Which looks fine when zoomed in, but in the PDF it's still quite flat. When the infection rate in my country will be less severe, I will send the PDF to my GP and let her decide whether it needs attention 🙂 Thanks everyone!
Best Answer05-24-2021 20:01
05-24-2021 20:01
Hi Yves just wondering if you were able to check the ECG with your family doctor. My husbands looks very similar ...
Best Answer11-26-2021 23:56
11-26-2021 23:56
Hello OlaF86, I also am getting these low voltage readings. Did your husband ever find out anything about his? Thanks.
11-03-2022 19:08
11-03-2022 19:08
This is an old post but the results look like my after heart failure. Hopefully you saw a doctor
Best Answer12-27-2022 06:34
12-27-2022 06:34
Does anybody know if this was resolved as mine is the same
