10-07-2022
09:43
11:29
LizzyFitbit
10-07-2022
09:43
11:29
LizzyFitbit
I have a Fitbit Sense 2 from March this year and till last week it worked perfectly. Since a week the startscreen is frozen and displays only the Fitbit logo. I have performed a soft reset (holding the left button for more than 10 seconds), and also a hard reset (holding the left button while the watch is connected to a power supply). What can I do?
10-26-2022 20:12
10-26-2022 20:12
Same issue is happening with my sense . No solution has been found till.date .Need sone support on this issue .
Best Answer10-28-2022 09:57 - edited 10-28-2022 10:51
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
Sense 2 was released in September, you have a Sense?
It is possible to reset The Sense And Versa 2 / 3using the button. I am not sure if it is any different from the normal "Hard Reset", but worth a try?
10-28-2022 22:01
10-28-2022 22:01
Looks like there are many people having the same issue
Best Answer10-29-2022 09:10
10-29-2022 09:10
Full charge not lasting a day. Attach charger and logo is stuck on screen. Really bummed. Is there a year warranty on these?
Best Answer10-29-2022 09:13
10-29-2022 09:13
Ive got the same problem with my fitbit sense ?? tried all the pressing button suggestions etc v annoying
Best Answer10-30-2022 00:31 - edited 10-30-2022 04:13
Hi, Sense screen keeps turning off and freezing every few days. Responds to a dozen clicks, but horizontal streaks appear on the screen until it finally settles. It's annoying. I tried to perform a reset according to the scheme described. Now I can't use it at all - a red cross (X) and the inscription "Data not cleared. Sync and try again" appear. No matter how hard I try, it's still the same. Is there a way out? Thank you.
P.S. Solved through support team.
Best Answer11-02-2022 19:54
11-02-2022 19:54
I have this issue with my sense. It did it after I turned on the recording option for snoring. It was fine then did a sync at about 530 am and quit working early Tues am. I have done the above steps multiple times. I have changed it over night. I have disconnected it from my phone and tried to pair it again even though it is stuck on the logo. I have had zero luck. I contacted fitbit. They have escalated it to a higher level but I have heard nothing back. I miss my sense and rely on it daily. Any other suggestions?
Best Answer11-03-2022 08:30
11-03-2022 08:30
This worked for my 6-month-old Sense! It was stuck in a permanent loop of the logo flashing on and off every 5-10 seconds. This allowed me to break the loop. I got the big red X on the watch and am now working to reconnect it to my phone.
THANK YOU!
12-26-2022 11:33
12-26-2022 11:33
What exactly was it that worked? I am having the exact same issue. Contacted Fitbit but they could not help other than holding the button down for 8 seconds but it’s resetting quicker than I can hold buttons down. Thanks for any help
