10-29-2021 15:48
10-29-2021 15:48
I started a Factory Reset from Settings/About/Factory Reset because the tracker stopped syncing with my Android phone.
The tracker rebooted
and shows now a big red X with "Data not cleared. Sync and Try again." text underneath.
In the app the tracker shows sync failed and will not connect to the tracker via Bluetooth.
How can I get the tracker to reset so I can start over?
Mike
Best Answer10-29-2021 16:42
10-29-2021 16:42
The steps in this thread ended up working
https://community.fitbit.com/t5/Sense/Sense-stuck-on-message-quot-Data-not-cleared-Sync-amp-Tried-ag...
after I let the Sense run out of power and plugged it back in to re-charge.
