08-13-2022
13:05
18:05
LizzyFitbit
08-13-2022
13:05
18:05
LizzyFitbit
My notifications stopped working after I added some games and the ISS tracker. I've tried everything, even uninstalled what I've added. I have paired, unpaired and restarted the phone and watch loads of times. Do I do a factory reset and hope for the best? Is the notifications the issue that lots of people are having, or is it the apps I added? - I need to resolve I asap as I rely on the notifications for my work.
Moderator Edit: Clarified subject and updated label
Best AnswerWhat is meant by doesn't work.
Does the Sense turn on?
Does the screen light up?
Is the time displayed?
Does the screen swipe?
Display steps?
Sync?
Notifications?
Are you saying that you removed the tracker from your fitbit account and set the sense up? To un-pair, the user removes the tracker from the phone's BT. The user can not pair. The user opens the fitbit app, and the fit it app will ask for permission to connect or pair. Android vs iOS.. The app, not the user handles the BT.
I assume a restart has been done, how about a shutdown.
20:39
11:00
Thank you. The thing is, the notifications stopped working about 2 days before the update, tbh I was hoping the update would fix it. 😔 I'll put the games back on and hope fitbit do a fix soon🤞🤞.
Best AnswerHi! Lots of questions! My watch is not displaying my notifications at all.
Pairing and unpairing have been between my watch and my phone.
I have been doing the shutdown on my watch and phone
I have not yet done a factory reset on my watch
08-14-2022
01:24
11:00
If the watch is not in DND or Sleep mode, it might be a communication issue and a shutdown of both the phone and tracker might help.
Otherwise the issue is with the phone.
Best AnswerHi, I have done a shutdown of both phone and watch, separately and together. It has not worked. That's why I'm asking if I should do a factory reset. But there's lots of chat about it being an issue with the update too.
