01-27-2021
12:20
03:55
WilsonFitbit
01-27-2021
12:20
03:55
WilsonFitbit
Samsung J6. Android 10. Sense stopped syncing yesterday after a few days of intermittent issues syncing. I tried all the trouble shooting suggestions multiple times. Finally I tried to re-add the Sense to the app. Big mistake. It won't connect to the app at all so now I have an app with no Sense connected and I can't set it up at all. Help.
Best Answer01-27-2021 13:40
01-27-2021 13:40
When you say you tried to re-add the Sense to the app I assume you removed the unit from your account. If that is so here are some steps to try:
1. Check your phone's bluetooth links and see if the Sense is still linked to your phone If it is, then unlink the unit to your phone.
2. Delete the Fitbit App on your phone and re-install it.
3. Re-start your Sense.
4. Now try and add the Sense back into your account.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
Best Answer01-27-2021 13:51
01-27-2021 13:51
Best Answer01-27-2021 14:46
01-27-2021 14:46
This has happened to me as well. I am running the Samsung A10e. My wife and I both have the same phone and both have a sense. They both quit syncing 1/25 in the evening and neither one of us have been able to sync since. We removed just as you did and now cannot reconnect them. As with your experience it sometimes finds it but will never connect to add the device. This morning my son who has a charge 4 has reported the same issue. This is disappointing and frustrating. I hope there is a fix soon.
Best Answer01-27-2021 14:57
01-27-2021 14:57
Me 2!
Got the same problem since the last update of the fitbit app.... better they fix it soon!! I have other issues like counting too many stairs also which it didn't do before... very annoying!
Best Answer01-27-2021 22:31
01-28-2021 03:54 - edited 01-28-2021 04:01
Hello everyone. @BeardedChris @Lilly093 Welcome to the Community Forums! @wtksk8r @Guy_ I appreciate your great input!
@Completelystuck @BeardedChris @Lilly093 As our friend @Guy_ informed above, our team is currently aware of an issue affecting the syncing process for Android users. They are working hard to resolve this as soon as possible. In the meantime, I suggest you to keep trying our troubleshooting steps and make sure that the Fitbit App and your Fitbit device are up to date to ensure you receive the quickest resolution.
We're very sorry for any trouble and thanks for your patience. I hope we can have a resolution soon.
On a side note, once there is a resolution, you may try to setup your device again. You can also refer to this link.
Keep me posted.
