09-28-2021
13:19
14:25
09-28-2021
13:19
14:25
My Sense has suddenly stopped syncing with my phone. I have done the following, and none of these steps has helped:
1. I have rebooted my phone.
2. I have turned on and off Bluetooth on my phone.
3. I have attempted to pair my phone with Bluetooth on my phone, and I receive the message "Pairing rejected by Sense."
I would appreciate help.
Thanks!
Best Answer09-28-2021 14:27
09-28-2021 14:27
Hi there, @slssls. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Sense before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Sense from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Sense.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Sense.
Hope that helps.
09-28-2021 14:27
Hope that helps.
14:40
15:15
09-28-2021
14:40
15:15
Thank you
Moderator Edit: Personal info removed
