01-31-2021 22:23 - last edited on 02-07-2021 18:44 by LiliyaFitbit
Got a brand new sense last week. yesterday it stopped syncing. read advice last night which said restart phone and watch. did both. now my sense will not turn back on. using android phone. very worried as watch is completely unresponsive. had almost 90 percent battery when turned off. anyone else not able to turn device on?? for a device that is less than a week old I am underwhelmed by whole experience
Best Answer02-01-2021 00:47
02-01-2021 00:47
The sense has an indent button which takes some getting used to.
try this technique
Worn on the left arm -
rest your other thumb on the arm to the left of the watch and forefinger on the back of the hand and do a gentle squeeze of the watch |
Squeeze for upto 10 seconds until you feel a faint vibrate or the logo appears
Best Answer02-07-2021 09:05
02-07-2021 09:05
it is a month later and again my watch will not sync with my phone. is this going to be a cyclical problem?
Best Answer02-07-2021 09:22
02-07-2021 09:22
Just to be sure, lets check your current status
What phone do you have?
What is your app version?
In the phone Fitbit App Click on profile photo [top left] Help & Support App Version at the top |
And what is your watch version?
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Firmware Version at the top |
And what version is showing on the watch?
On the watch Swipe left Settings Scroll to About Sense / System info Version near the top |
Best Answer02-12-2021 08:49
02-12-2021 08:49
I have a galaxy A9 2018
app version 3.37.1
watch version 44.128.4.17 as seen on app
watch version as seen on watch 44.128.4.17
The watch usually syncs when I plug it in to charge in the morning. this morning it didnt but synced this afternoon when not charging. it does not regularly sync and this renders is functionality reduced.
Your help so greatly appreciated for an expensive watch that does not work properly. many thanks
Best Answer02-12-2021 10:35
02-12-2021 10:35
Thanks for the feedback, you are at the latest levels and it should work well.
Not quite sure what the problem is now, are you still unable to turn the watch on, and is it unresponsive?
If its syncing, guess that problem is resolved, however for watch face problems it could be a clock face issue and an alternative clock may resolve it.
If its having problems syncing or staying synced consistently
Try this to disable battery saving.
On the phone check battery optimizations [the options may be different in your version]
See how that goes.
