12-27-2020
07:38
04:00
12-27-2020
07:38
04:00
I made an earlier post but didn't get any responses. My two well old sense is doing nothing but restarting. The logo comes on the screen or goes black and then repeats this over and over again. The back lights do not turn on at all.
Best Answer12-27-2020 21:55
12-27-2020 21:55
@w2wma that's not a good sign. It seems like poor sense got stuck in a permanent loop. At this point I'm afraid you need to reach out to Customer Support for the replacement.
Best Answer12-29-2020 14:05
12-29-2020 14:05
Same here since update
Best Answer12-29-2020 14:15
12-29-2020 14:15
If I force closed the app, it stopped. Restarted the app and hasn’t happened since (few minutes, but the problem was continuous) so worth a try. On Android
01-19-2022 04:31
01-19-2022 04:31
this is an issue with mine too and i didn't even get it set up yet. They rushed this watch and it has so many issues.
Best Answer09-10-2022 19:12
09-10-2022 19:12
Mine started doing this too. Fitbit NEVER stands behind their product quality. These devices last 1 year at most.
They offered me a 35% discount but NOT on newer generations.
I let them know I'll just purchase a new one at the store and stick my DEFECTIVE sense back in the box and return it and keep the new one. The store doesn't lose out since they charge back fitbit. If fitbit has enough returns they might fix their defects
Best Answer09-12-2022 08:46
09-12-2022 08:46
Lasted only a few months for me. My old blaze lasted a couple years. I feel like I rely on my data a bit (nurse). I cleaned it ,trouble shooted, really took care of the watch never really got it wet besides washing hands. Mine started cycling and then stuck on clock screen and heated up badly.did customer support but felt a little watch and heating up but unfortunately they want mine shipped to them with OG charger with logo and I don't have that anymore due to the many replacements I had to purchase.
Best Answer12-04-2022 15:00
12-04-2022 15:00
I've had two Senses, the first one had this issue about two weeks into me owning it. I contacted customer support and they did not have a fix, so they sent me a second one. The second one just started having the same problem since yesterday.
Has anyone figured out a fix for this problem? No matter how many times I try restarting it, it does the same exact thing, it just keeps restarting over and over again.
Best Answer12-04-2022 20:50
12-04-2022 20:50
