01-13-2023
04:11
05:06
01-13-2023
04:11
05:06
Fitbit sense stuck in reboot / startup loop. All prior posts have the same reset suggestion and it's not working on this sense. What else to do? Thanks
01-14-2023 05:08 - edited 04-29-2024 04:39
Hi there, @hollytolo. Thanks for stopping by in the Community Forums and already trying to troubleshoot the issue with your Sense.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with the Fitbit Sense, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer01-14-2023 05:08 - edited 04-29-2024 04:39
17:46
07:01
DavideFitbit
01-14-2023
17:46
07:01
DavideFitbit
While I will try this, I would like to make it known that the reason this
is occurring is not because I was performing a factory reset without first
unpairing my device from my account and Bluetooth settings. This started
while I was having a standard day, not even utilizing my device or account
to any specific extent. I will update when advice for fix is completed.
Thank you.
Didn't work. It's still stuck in the reboot loop. The app will not find the sense.
01-16-2023 23:56
01-16-2023 23:56
Im having the same issue. I was sleeping and it just started to vibrate for a second. Now it wont stop, it vibrates once every 30 seconds. I went through all of these steps and the app cannot find the Sense.
01-17-2023 05:47
01-17-2023 05:47
There are now two of us with this issue. Please advise.
01-17-2023 05:53
01-17-2023 05:53
I'm having the same issue. Mine went dark last Tuesday while I was at work. I wasn't touching it either. Tried resetting, draining the battery, nothing.
01-17-2023 06:52
01-17-2023 06:52
Same issue for me too...
01-17-2023 10:19
01-17-2023 10:19
I am having the same issue. I was asleep and woke up to the fitbit logo on the screen. Thought I need to charge and not working. I can not reset or turn off my Sense.
01-17-2023 11:00
01-17-2023 11:00
Clearly some update was done and now everyones watches arent working!
01-17-2023 14:27
01-17-2023 14:27
Your suggestion didn’t work and this is not the first time a Fitbit device that I have owned has done this. It happened with my Ionic and now it’s happening with my Sense.
Last time this happened with my Ionic, after tying the same troubleshooting suggestions, Fitbit said it could not be fixed, and that they would give a discount towards a replacement. It’s super frustrating to deal with the lack of durability these device seem to have.
01-17-2023 16:18
01-17-2023 16:18
I just called and basically I have to get a new one. Luckily... I think... mine is in the warranty window that I do not have to pay... but they still shouldn't be charging people if it's a defect in the product!!!
01-17-2023 16:26
01-17-2023 16:26
What number did you call? How long have you had your Sense?
Best Answer01-18-2023 06:10
01-18-2023 06:10
Now there are 3 people with same complaint
01-18-2023 06:36
01-18-2023 06:36
So I spoke with Fitbit rep , since my Sense is doing the same thing, and they said they did not have this reported as a common problem . Not sure, but hopefully everyone having this issue is notifying Fitbit so they can hopefully resolve. I didn't get any resolution to it 😡
01-18-2023 07:04
01-18-2023 07:04
Please repond to us. A number of people are having the same issue. Thank you.
01-18-2023 08:03
01-18-2023 08:03
So I went through the Fitbit support line and told them I’ve tried the suggested troubleshooting to no avail. They gave me the option of either 50% off a new device or a free Sense replacement. I chose the replacement, but I will probably be posting the same message in a year or so as that seems to be how long these last. This will be the last Fitbit product I use. Hope everyone else gets their stuff sorted out soon.
01-18-2023 08:04
01-18-2023 08:04
Thanks for this. I'll try calling next too.
01-18-2023 08:29
01-18-2023 08:29
add me to the list
01-18-2023 15:11
01-18-2023 20:13
01-18-2023 20:13
I am having the same issue with my device!! I did as suggested and it is not working… Still in the reset loop!! PLEASE ADVISE!!!
