02-18-2021
08:08
13:49
LizzyFitbit
02-18-2021
08:08
13:49
LizzyFitbit
My steps on fitbit sense advanced are different than the fitbit app. How do I fix this?thanks Shannon
02-19-2021 10:59
02-19-2021 10:59
Hi @ShannonGarr, it's nice to see you here in the forums.
Just to confirm, do you see more steps on the Sense than the Fitbit app? If that's right, it might be that your watch isn't syncing and updating your data correctly. Please make sure the Fitbit app is updated and give a try to the following:
I look forward to your response.
02-19-2021 13:39
02-19-2021 13:39
02-21-2021
13:44
09:35
02-21-2021
13:44
09:35
Hi @ShannonGarr, I hope you're doing well.
Because your Sense is having a different behavior, I've moved your post to this new thread so we can keep our forums organized. I understand your concern about getting that amount of steps without doing an intense activity. Could you please check if you have MobileTrack setup in the Fitbit app? Let me explain that MobileTrack is a feature that records basic stats such as steps using your phone's sensors if you don't have a Fitbit device available. However, if you're using it along with a Fitbit device, it'll affect the information recorded by your watch and sync incorrect details in the Fitbit app.
Assuming this applies to you, please follow these steps to remove this feature from your account:
Please note that currently it's not possible to delete the incorrect steps that were already synced, however you can log a non-step-based activity such as driving to override those steps. For more instructions see this help article.
