05-31-2023
03:59
06:47
05-31-2023
03:59
06:47
So I've had my Sense for about 2 years and in the last week or so it seems like the vibration has been getting weaker. I do have it set to strong the whole time. I'm not sure if I'm finally just getting too used to it or if it's really getting weaker. Is anyone else noticing a change in the vibration strength in older Fitbits?
05-31-2023 21:15
05-31-2023 21:15
Hi @o1liver11 - the difference between Light and Strong is virtually imperceptible so will have little effect, though if you have to change it check your Quick Settings, swipe watch face to the right and make sure Sleep is not enabled, as this sets it to Light.
How tight and where the watch is worn can have a marginal effect. Possibly how accustomed you are may have a greater but minor effect.
It should be noted that battery level does have a slight effect, at lower levels the vibrations are weaker.
Also there are 8 types of vibrations and if you want to compare them you can use the SimpleVibrate app.
