01-11-2021 20:31 - last edited on 01-15-2021 08:58 by WilsonFitbit
I am frustrated by the volume on my Sense. I have tried both Alexa and phone calls and the volume is so low it’s barely audible. I’ve tried tapping the volume icons in both apps and that has provided very little change. I can’t believe this is the best it can do after paying what these go for.
Has anyone found a real solution to volume issues?
01-15-2021 08:55
01-15-2021 08:55
Hello everyone. @Guy_ Thank you for the input!
@TonyMan when dealing with any Bluetooth devices, compatibility issues may arise. I recommend connecting sense to different audio devices; you may try with a Bluetooth speaker or headphones. Note that there are some Bluetooth headphones that work better.
Keep me posted.
01-12-2021 00:10
01-12-2021 00:10
Hi, when in a call did you find the speaker in the top right corner on the watch and manage to increase the volume?
Its a tiny speaker so one can't expect miracles. Works fine for me in a quiet environment.
If you are in a noisy environment there is the option of using your phone, seems like a good compromise.
01-12-2021 04:12
01-12-2021 04:12
While I have heard of others complaining about the audio volume of their sense watch, I have not experienced it.
I haven’t had the need to increase the volume via the watch speaker control. If need be you can also increase the volume on the phone.
the volume gets quite loud for me. I even have a low degree of hearing loss in my left ear from my younger days.
Callers on the other end have stated I sound fine with no prob hearing me as well.
Try the watch volume and phone volume as suggested by Guy.
01-15-2021 08:55
01-15-2021 08:55
Keep me posted.
08-25-2021 12:28
08-25-2021 12:28
I have the same issue - I can barely hear it. I turn it up using the small speaker while in use - but it reverts back to the low setting after the call. So each time I have to turn it up. Is there a way to keep it at the higher volume?
05-29-2022 18:32
05-29-2022 18:32
Same, that is annoying. I wish it would stay at the higher volume we find we need to set it to rather than going back to that inaudible level. 😞
