01-09-2021
12:47
04:47
DavideFitbit
01-09-2021
12:47
04:47
DavideFitbit
My husband took a q-tip and cleaned the ports on the back of my watch, apparently just rubbing or whipping the back of my watch with the rubbing alcohol was not working that just pushed dirt into the contact holes on the back of my watch. After he cleaned it with the q-tip my watch is now charging. Take the end of the q-tip, dip it in alcohol and push it into the contact hole on the back of your watch turn the q-tip back and forth a few times and you should see some dirt on the end of your q-tip, if your watch is dirty. He did this a couple of times and he also cleaned the prongs on my charger. This did the trick, but not before we went out and bought a new charger thinking that was the problem. Hopefully this will help someone else on here. 😁 Good luck!!
01-12-2021
04:47
08:41
01-12-2021
04:47
08:41
Hi, welcome to the Fitbit Community forums @Tdoherty0415!
Thank you for sharing your experience with this, it's great to know that you were able to resolve by cleaning the back of the watch. I'm sure this will be useful for other users as well.
Have a great day.
01-12-2021
04:47
08:41
01-12-2021
04:47
08:41
Have a great day.
03-26-2021 08:35
03-26-2021 08:35
It worked! Thanks a 10^6
03-26-2021 09:51
06-28-2022 17:23
06-28-2022 17:23
Worked first time but now it won’t charge at all. Tried multiple chargers, none will work. Thinking of switching to Apple
06-29-2022 04:33
06-29-2022 04:33
06-30-2022 10:42
06-30-2022 10:42
This worked for me for a few days. Then it went dead. I got a replacement and it did the same thing in about 5 months.
06-30-2022 13:56
06-30-2022 13:56
Thanks for this ‘tip’! I’ve used and old tooth brush with alcohol with limited success. I’ve also taken high grit emery cloth to the prongs on the charger to back sure they were able to contact well. (Just one pass is enough)
07-09-2022
12:44
08:25
07-09-2022
12:44
08:25
Hi everyone, thank you for sharing your experience with this and for confirming that some of you were able to resolve or got in touch with the Support team.
There are a few general recommendations listed in this article to resolve problems with the battery. However, if you already tried all these steps and you continue to have the same problem, I do recommend that you continue the communication with the Customer Support team so they can provide you with the next steps.
The best way to get help for this problem is to chat with us online or give us a call. You can click here to get connected.
