08-08-2023
09:44
07:21
08-08-2023
09:44
07:21
I have been trying to recharge my fitbit for over a month now and it does jot work. I thought it might be my plug or the electric outlet but nothing is working. Have you experienced a similar problem? Were you able to fix this?
Moderator Edit: Clarified Subject
Best Answer@Cynber17 Have you tried buying a new charger for your device? There are reports of the charging pins on the Sense charges that will collapse and you won't be able to charge.
Hello there, @Cynber17. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Sense before reaching out.
In addition to the suggestion provided by @Heather-S, I'd like to confirm that you've tried all troubleshooting steps provided here Why isn't my Fitbit device's battery charging?
