06-09-2021
05:37
07:02
WilsonFitbit
06-09-2021
05:37
07:02
WilsonFitbit
My Fitbit won’t charge. I’ve cleaned the device and the charger as directed in instructions but still not charging. What else should I do?
06-09-2021 06:13
06-09-2021 06:13
There's a common problem with the Sense chargers, where the 4 pins are not equally prominent, so don't make good contact.
Probably best to contact Fitbit Support directly. They may be able to help you with a replacement charger.
06-09-2021 06:13
06-09-2021 06:13
06-09-2021 06:22
06-09-2021 06:22
06-12-2021
06:59
11:05
06-12-2021
06:59
11:05
Hello @DPB3. Welcome to the community forums! @Guy_ It's nice to see you around and thanks for your input!
@DPB3 Thank you for the information and for the troubleshooting steps you've tried. I was able to see that @Guy_ provided information about your inquiry and if it was the answer you were looking for, I recommend marking the answer given as the best answer. By doing this, other users with a similar inquiry will find a faster response.
See you around.
06-12-2021 13:21
06-12-2021 13:21
I have the same problem.
Best Answer06-12-2021 13:55
06-12-2021 13:55
Three of my pins stick up, but the fourth is pressed in. Fitbit Sense will not charge. Thanks for posting this which caused my to look at my charger. Unfortunately, Fitbit is closed on weekends. Guess I'll call Monday.
06-13-2021 00:27
06-13-2021 00:27
10:16
11:05
06-14-2021
10:16
11:05
Hello @cfgod, @Cigarmac. Welcome to the community forums.
Thank you for the information. @cfgod I'm glad to hear that your Sense was able to charge and now it's up and running.
@Cigarmac I was able to see that you have reached out to our Support Team and they will send a replacement charging cable. I hope you can receive it soon, so you can continue tracking towards your fitness goals.
See you around.
06-14-2021
11:51
12:05
WilsonFitbit
06-14-2021
11:51
12:05
WilsonFitbit
Thank you. The post about 4 pins being prominent on the Sense charger was right on. I only had three pins “up” so no charge could occur. The Fitbit Forum is very useful. Mac
Sent from my iPhone 8
06-18-2021
07:03
11:05
06-18-2021
07:03
11:05
@Cigarmac Thank you for your reply.
Nice to hear that the information that was shared in this forum, helped.
Have a wonderful day!
Best Answer08-13-2021 14:25
08-13-2021 14:25
Hi. I actually bought a new charger - as I wrote in my post - and it doesn’t work either. What options are there? Can i get a replacement? I bought it less than a year ago. Thank you for your response.
S
08-13-2021 17:40
08-13-2021 17:40
You should contact the Fitbit Support Team or Try: https://myhelp.fitbit.com/s/support?language=en_US They were very helpful when I explained what I really needed, though I had to go through their standard procedure of "did you do this" YES, "did you do that" YES, etc. Only takes a little time, and then they can fix the problem, send you what you need, etc. My Sense was only 6 months old, so still under warranty.
08-14-2021 03:59
08-14-2021 03:59
Hi @SallieMIA - If you bought a new charger that connects to the watch and it still doesn't charge have a look here.
08-14-2021
05:28
11:04
08-14-2021
05:28
11:04
Hello @SallieMIA. Nice to see you around! @Cigarmac, @Guy_ It's great to see you around and thanks for your input!
@SallieMIA Thank you for buying a new charging cable. At this time, I'd like to let you know that I was able to see that you received assistance and information about how to get in touch with our Support Team in this thread. Note that they will be able to review your options and get back to you with more information.
If you still have additional questions, I'd recommend replying back to your original thread, this way we can keep our forums organized.
@Cigarmac I am also glad to hear that Support was able to help you.
See you around.
11-10-2021 14:11
11-10-2021 14:11
This problem affected me, too, twice. I had one Sense charger replaced about a year ago (it was still within the one year warranty). It happens again, today. The symptom is the same (stuck pin at one corner). I just called in support; I'll be receiving a free replacement charger cable (thank you Patrice!) By the way, the support experience has been great this time (last time, it was more like a wrestling match with the support rep!)
01-29-2022 06:48
01-29-2022 06:48
I've received a replacement charger, asked for another one this week and two different support reps told me I'm out of warranty (by 3 months) and to buy another charger myself.
This angers me more than anything. There many people who have complained about the same exact problem. It's not user error it's a problem with their product design. Instead of taking care of customers they will ask you to give the company more money buy buying another charger that will inevitably fail.
After having this sense, versa, charge 2, fitbit one and fitbit aria scale this is the last time I will ever buy a fitbit product or recommend them to any of my family or friends.
Best Answer01-29-2022 07:43
01-29-2022 07:43
So your first post in the Fitbit community is to announce you're leaving?
Okay. 👋🏼
04-30-2022 10:43
04-30-2022 10:43
My fitbit sense has not charged all week. Only 6months old and the troubleshooting is not working. I tried cleaning using a bit of alcohol. Does updating software or firmwire correct this issue? Really disapponting to get battery problems on fitbits premium device
04-30-2022 13:03
04-30-2022 13:03
It makes me angry that a $400 watch has a $2 strap and a charger that often won't work. The price this device costs it should have a quality strap and a charger that WORKS!
04-30-2022 13:37
04-30-2022 13:37
