05-01-2023
07:18
08:33
05-01-2023
07:18
08:33
Sense seems to start charging, then battery levels start declining (rapidly) and end up near zero. Sometimes it charges, sometimes it doesn't. Pain in the rear.
Hi there, @Kakelly. Thanks for stopping by in the Community Forums. Thanks for the details provided in your post about the issue with your Sense. I understand how you must be feeling.
If you haven't done so yet, please see Why isn't my Fitbit device's battery charging?
Best AnswerMine would not charge because I needed a new charge cord. Make sure what apps or locations you set are not using up your battery so fast. If you have a clock face that is set to always on, it will use up battery really fast.
Restart to fix Fitbit charging issues
If cleaning and checking the charging ports and cable doesn't work, try restarting your Fitbit. To restart most Fitbits, press and hold its side button(s) for around 15 seconds until you see the screen turn back on with the Fitbit logo or another icon
Regards,
Diana
