06-24-2023
07:28
11:34
06-24-2023
07:28
11:34
I have been using Sense from past 1.5 years and suddenly one day it has stopped taking charge
How i will get to know whether issue is with charger or the watch, and whatever be the issue how i will get it corrected please?
Please solve my problem please
Best Answer06-24-2023 08:33
06-24-2023 08:33
Check to make sure the 4 pins aren’t stuck. I had 1 that collapsed and wouldn’t make contact.
Best Answer06-25-2023 08:59
06-25-2023 08:59
Can you share how you fixed the collapsed pin?
Best Answer06-25-2023 09:10
06-25-2023 09:10
Uno dei PIN mi sembra che sia un po' più basso degli altri 3, come faccio a ritirarlo fuori?
06-25-2023 20:52
06-25-2023 20:52
See the procedure for not charging - How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
