05-13-2021
17:48
15:19
LizzyFitbit
05-13-2021
17:48
15:19
LizzyFitbit
Recently I'm experiencing a problem where the Voice Assistant (Alexa) on my Sense keeps deactivating. Several times a week now I go to use Alexa and I am prompted that I need to setup the Voice Assistant on my device. Why is this happening and how can I resolve it?
Note: This is different from the issue where the Sense reports connection lost and to sync device.
Moderator Edit: Clarified subject and updated label
15:26
07:42
06-25-2021
15:26
07:42
Hi everyone. Thanks for participating in the forums and welcome to our new members.
I've moved your posts to this new thread. The issue will be resolved by updating the Fitbit app version on your mobile devices to app version 3.42.1 or above.
Hope this helps.
05-14-2021 01:52
05-14-2021 01:52
I have the same issue. Every time I restart my mobile I need to activate Alexa again.
See also here:
After the last update, I have set up Alexa daily - Fitbit Community
Best Answer05-14-2021 08:31
05-14-2021 08:31
Have had my fitbit sense since the 6th .. Only a week or so and can say for certain that happens to me often, usually after extended periods over several hours of nonuse of the assistant feature, usually syncing works, connecting to bluetooth services but some reason it just stops..
Ive been force stopping the app and then just opening and hit sync again it works. Some times I gotta log right into assistant again within the app.
So its obviously something to do with the handshake and or signature... Could be wrong but it seems like the most likely reason specially if i gotta add the assistant thing again at times..Wifi also sometimes says disconnected... i dont always hold my phone in my hand at home i place it down and walk away so is it loosing the wifi connection and then drops the handshake between assistant in the app. Least what i have noticed.
Best Answer05-14-2021 10:33
05-14-2021 10:33
Having the same problem. Alexa keeps disconnecting as well as my Spotify account.
Best Answer06-02-2021 14:56
06-02-2021 14:56
When I bought the fitbit sense, Alexa used to work and everything was fine. Recently, is always asking for the set up to be completed. That happens about twice a day.
My wife has the same issue.
I've read all the threads about this and nothing works. Reinstalled all, cache deleted, etc.
Alexa doesn't work.
Alexa was one of the main features we bought this watch.
Any help?
06-02-2021 18:34
06-02-2021 18:34
Hi @IonicFan01,
Have you tried switching to the Google Assistant and then back? Sometimes I have to do this as well.
one cruise ship at a time!06-03-2021 03:12
06-03-2021 03:12
Thanks DramaQueenDiva,
I've tried and it didn't solve the issue. Every few hours, Alexa wasn't working again.
I'm using now the Google assistant, and even if it doesn't have voice, it works. 2 days in a row and counting.
I really thing they have messed Alexa up with any update.
Regards,
Best Answer06-04-2021 02:04
06-04-2021 02:04
When you are used to having access to Alexa your wrist, it's very annoying when it doesn't work!
During the last few weeks I've noticed that Alexa just won't stay connected to the Fitbit watch/app. It even says "Active" but when I click on it, I get the same "Log in to connect to Alexa" screen.
What gives? Is this a known issue?
06-11-2021 06:19
06-16-2021
16:42
15:11
LizzyFitbit
06-16-2021
16:42
15:11
LizzyFitbit
I have had my fitbit sense for a very long time and all of a sudden it will not connect to Alexa, what happened and how do I fix it.. When I try to turn it on I get an error message from alexa saying connot connect. I am so frustrated I have tried everything
Best Answer06-17-2021 09:05
06-17-2021 09:05
Have you installed the latest firmware update. Somewhere along the way Fitbit replaced my Alexa app with Google Assistant. I don't see it in the app store now.
Best Answer06-17-2021 09:24
06-17-2021 09:24
06-17-2021 10:22
06-17-2021 10:22
You may need to call support.
Best Answer06-18-2021 07:33
06-18-2021 07:33
I have many many many times, I'm exhausted with this it's time to dump my fitbit and find something more relyable.. There scale doesn't work either it's just a huge paperweight in my bathroom.. OK well thanks for the reply..
06-23-2021 21:45
06-23-2021 21:45
Why does my Fitbit Sense go offline in the Alexa app? What settings should I check?
Best Answer06-23-2021 22:41 - edited 06-23-2021 22:42
It usually is because Alexa can't connect to the phone. Or because of a fitbit app update, permissions have been reset.
If this is a permanant error, try setting Alexa up, the app will prompt for all needed permissions.
06-24-2021 12:02
06-24-2021 12:02
Thanks Rich,
If I sync my Fitbit Sense with the Fitbit app and leave the Fitbit app up (running in the background) on the iPhone.
Then go to the Alexa app,
the Fitbit Sense is online with Alexa and I can change or modify routines or reminders.
But soon the Fitbit Sense device in the Alexa app seems to timeout (go offline). The reminders still work if I have saved them.
Best Answer06-24-2021 23:17
06-24-2021 23:17
I'm not understanding you @ldamario55
The Alexa app is only active when the user activates alexa.
The tracker never stay connected to the phone, but as a trusted device, it connects when needed.
Therefore alexa is not suppose to stay active or connected to the phone.
The Fitbit app needs to be running in the background so trust it may link up with alexa.
06-25-2021 12:55
06-25-2021 12:55
Hi,
I have setup and successfully used alexa from my sense. But whenever I try to use it later it tells me it is not setup and to setup on the phone. When I go to the phone, fitbit, sense, voice asistant it shows "not connected" against alexa. I then have to click alexa and tell it to connect, which it happily does with a few prompts and everything works OK again until the next time I try to use it in anger.
Fitbit does seem to be setup to run in the background on the phone, so I don't understand why it keeps disconnecting. Rather makes it pointless as I have to go to the phone every time before I can use alexa.
Any thoughts or ideas please?
06-25-2021
15:26
07:42
06-25-2021
15:26
07:42
Hope this helps.
