02-21-2022 13:53
02-21-2022 13:53
Hi there.
My Fitbit sense wasn't connecting to my messages, updating, calls, counting my steps properly etc etc.... So I disconnected it, turned it off, deleted the app and try to set up again..
It then wouldn't connect to Bluetooth or WiFi. So I restored factory settings and now it won't even allow me to pass the initial phase of set up. Still won't recognise or connect to Bluetooth or WiFi. It's less than 6 months old
Best Answer02-22-2022 05:33 - edited 02-22-2022 05:34
Hi @Katiecollins Try restarting it. If that doesn't help then contact Customer Support They should be able to help you
Helen | Western Australia
Best Answer02-22-2022 06:10
02-22-2022 06:10
@Katiecollins Make sure that "Sense" and "Sense Controls" are also deleted from your phone's Bluetooth devices. I don't think it's exactly necessary (I remove and add my Sense once in a while and don't do that) but it might help.
Best Answer02-22-2022 07:36
02-22-2022 07:36
Best Answer02-22-2022 07:37
02-22-2022 07:37
02-22-2022 07:48
02-22-2022 07:48
@Katiecollins Was it fixed or are you getting a replacement?
Best Answer02-22-2022 10:47
02-22-2022 10:47
