11-29-2020 08:43 - last edited on 12-07-2020 16:16 by LizzyFitbit
Having issues connecting my fitbit sense with Google Assistance.
when I follow the guide on screen in the fitbit app it takes me to an error page 400
Moderator Edit: Clarified subject and updated label
12-07-2020 16:48 - edited 12-07-2020 16:48
Hi @Sbohra. Welcome! It's good that the community is growing.
Thanks for bringing this to my attention and for your efforts while installing the voice assistant on your Sense. Before anything else, please make sure of the following factors which are required to install and use Google Assistant
If those conditions are met, I'd recommend to log out from the Fitbit app, force quit the Fitbit app, reboot your phone and restart your watch. Then, open the Fitbit app, pull down on the screen to force a manual sync and try activating Google Assistant one more time.
Let me know how it goes.
02-27-2021 15:20
02-27-2021 15:20
This worked for me.
Thank you.
Now to get it so I can actually connect my bank. Any tips on connecting my bank?
03-01-2021 10:54 - last edited on 01-29-2024 09:56 by MarreFitbit
Hi @SunsetRunner, welcome. It's good that the community is growing!
You're welcome, I'm glad the steps suggested in my posted worked for you. In regards to your other question, please make sure your country and bank appear in the supported banks list. Once you've confirmed that, I'd suggest you to follow the instructions described in this help article to set up and use Fitbit Pay on your Sense.
Hope this helps.
08-26-2022 23:15
08-26-2022 23:15
I’m having the exact same issue. I’ve followed the steps in you answer but still can’t get it to work, just keep getting forwarded to the Google 404 page. What should I do?
