10-29-2020
15:50
14:12
LizzyFitbit
10-29-2020
15:50
14:12
LizzyFitbit
My Fitbit sense won't locate my phone or receive notifications.
I have checked it's Bluetooth connected.
Best AnswerHi @hrgflores what type of phone are you asking about?
When you say can't locate, are you asking about the find my phone?
09:13
04:47
AlvaroFitbit
10-30-2020
09:13
04:47
AlvaroFitbit
IPHONE
I'm asking about the feature to locate your phone off of your fitbit. "find
my phone".
Thank you,
Moderator Edit: Personal info removed
I understand this @hrgflores both notifications and the Find phone require the Fitbit app to be running in the background.
It most likely is that the phone is not sending notifications.
Once Notifications start working, the find my phone should also work.
If you where android I could help more.
Please check the notification setup guide.
Some things to check or try are.
Open the Fitbit app.
Go to settings / Sense / Notification / tap the three dots found in the top right / send test notification.
Make sure that the Fitbit app is able to run in the background.
IOS users have also mentioned giving permission to fitbit in their notification center.
Have someone send a text to you while your Fitbit app is open on the phone.
Best AnswerYes I'm having the same problem with the FIND MY PHONE app feature.
My phone receives notifications fine, but the find my phone feature from the watch to the phone doesn't work.
Other forums suggest turning turning phone off and Sense off, but it makes no difference.
Looks like another FitBit gremlin.
After a very difficult, arduous process, I finally got fitbit to replace the watch over this issue but the problem remains. This is clearly an app/watch design issue. I do notice that if I manually sync the app to the phone, the find phone feature will work immediately afterward. Then as the day goes on, the feature stops completely.
09:59
12:58
04-09-2022
09:59
12:58
@Dj9281 - this would seem to indicate a phone issue, not a watch issue.
Each type of phone has its own peculiarities and work arounds, but the best place to start is with checking the phone battery saving feature isn't closing Bluetooth or the Fitbit App.
Another good test would be to use SimpleCheckUp app on the watch.
You can see when find the phone is not working whether the watch can connect with the phone and if it can then it is not a syncing problem.
Best Answermine worked on my iPhone 6s Plus and works on my
12 pro max. It must be a setting or maybe the alarm
does not work on the sense. Really odd to me.
Please see attached based on your app. Tried several times. Wouldn’t connect to your app or notify phone. What does this mean?
09:49
11:12
04-16-2022
09:49
11:12
Hi @Dj9281 - it means there is a syncing problem.
often if more than one Bluetooth device is used or there is an incorrect setup.
As a first step try restarting both the watch and the phone, this often solves the problem, before looking into other possibilities, which are listed here Why won't my Fitbit device sync?
@Dj9281 - have you tried
