02-16-2023
03:02
09:03
02-16-2023
03:02
09:03
I have had a Fitbit sense for just over a year and have had no problems. I had to go abroad on business for about 3 months and forgot to take my Fitbit sense with me, when I came back the Fitbit sense was dead, I charged it overnight did not help, other charging cable, did not help. The sense does not respond, no vibration, not at all. Pressing the button for 10 seconds doesn't help. Tried it multiple time, doesn’t help. Any advice?
02-16-2023 05:21
02-16-2023 05:21
Hi @Denzel1964 - corrosion may have set in on the contacts during that time, make sure you clean it properly and check the cables fully. See the guides in this article How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Once a battery goes into deep charge it may require persistence over several days and cleans and different power supplies.
Try pushing the button while charging, if there is a good connection.
Your post is moved to the Sense forum to which it relates.
02-16-2023 05:49
02-16-2023 05:49
Thanks, I ll try and will keep you posted
